What components are common culprits of frying bacon sound?
joulupukki
I've got an AionFX Aurora Deluxe compressor pedal I built. It's probably a little over a year old with not that much use. Over time, it's progressively gotten worse though and at startup (and sometimes for a couple of minutes when I try to engage it after startup) it sounds like frying bacon. Yesterday, when I first tried enabling the compressor, it had really low volume and static. After a couple of cycles of bypass and back it started working and was then reliable.
Any suggestions or techniques I should use to zero in which of the many components in the circuit, could be bad?
Here's a little video of the frying bacon sound at startup:
If it does it mostly at startup and it gets progressively better over time, it sounds like a bad electrolytic capacitor to me. Though I must say I've also seen a few op amps do that... If you have some Freeze Mist around, it could help with narrowing down a specific component.
