What is NPN and PNP transistor?
harpersophia
NPN and PNP refer to the arrangement of the pieces that make up the transister. ... An NPN transistor has a piece of P-type silicon (the base) sandwiched between two pieces of N-type (the collector and emitter). In a PNP transistor, the type of the layers are reversed. Below is a typical cross section of a transistor.
Can I use PNP instead of NPN?
Generally, the PNP transistor can replace NPN transistors in most electronic circuits, the only difference is the polarities of the voltages, and the directions of the current flow. PNP transistors can also be used as switching devices and an example of a PNP transistor switch is shown below.
