time to get a breadboard.
im serious, if you really want to get a quick tangible grasp on what to expect from your devices, pick a circuit, breadboard it, and see how you go.
then when you find something doesn't sound (or measure) right or whatever, it's as easy pulling a resistor and plonking a different value in there and hearing the difference immediately.
people can talk numbers and theory all day, but none of it really means shit until you hear things for yourself.
perfect candidate for your first breadboard project
I have a PNP device, and I really want to build and run negative ground. Can I "turn the circuit upside down" to do that?
A: It has been done, it sometimes works and sometimes oscillates badly. Not recommended.
This is important because lots of times it is said that circuit can be adapted from NPN to PNP transistor by simply reversing battery polarity. In reality, it is slightly more complicated than this.
You only swap polarity for the amplifier – and that’s what I highlighted above. If you’d swap the polarity completely, jacks would be connected to 9V instead to GND and that might not be the healthiest option for subsequent pedals/amp.
the jack sleeve also goes to ground.Why would simply swapping the battery polarity affect the jacks?
This is not necessarily true. You can use 0v as ground for the jack sleeve, rather than 9v, in the scenario that you outlined and it will work fine.the jack sleeve also goes to ground.
if there is +9V going to ground, and therefore also the jack sleeve, this can affect other pedals in the signal chain, as all of their jack sleeves will have continuity to the same ground (via patch cables).
which part?This is not necessarily true.
i really like this design though.
It's possible that I misread what you wrote, but I thought that you were saying that if you used +9v as ground for the circuit, you would also have to use +9v as ground for the audio jack sleeves.which part?
i said 'if there is +9V going to ground...'
i didn't say '+9V must go to ground'
(just trying to understand where I've got it wrong)
nah i meant if +9V is going to ground ground (as per 'vintage' schematics). my bad, i should have been clearer.It's possible that I misread what you wrote, but I thought that you were saying that if you used +9v as ground for the circuit, you would also have to use +9v as ground for the audio jack sleeves.
I’m working on a PNP circuit with no led and no dc jack, and followed this setup (below). Wondering if what you’re saying would be advisable, or even possible in this scenario with regards to the audio jacks connecting to “normal” negative ground. I’d love to avoid any issues with NPN pedals elsewhere in the chain.This is not necessarily true. You can use 0v as ground for the jack sleeve, rather than 9v, in the scenario that you outlined and it will work fine.
Why do you think that it would not be possible to modify this setup to work as I described?I’m working on a PNP circuit with no led and no dc jack, and followed this setup (below). Wondering if what you’re saying would be advisable, or even possible in this scenario with regards to the audio jacks connecting to “normal” negative ground. I’d love to avoid any issues with NPN pedals elsewhere in the chain.
So it would be ok to simply connect In/Out sleeves to the board’s -9v pad (with the battery’s -9v lead) instead of the board’s positive ground pad? In that case it seems like nothing would be connected to the board’s positive ground other than the footswitch… maybe that’s ok?Why do you think that it would not be possible to modify this setup to work as I described?
Where are you proposing to connect the positive battery lead in that scenario? You're overthinking this. Just use Figure 6 from that page rather than trying to reinvent the wheel.So it would be ok to simply connect In/Out sleeves to the board’s -9v pad (with the battery’s -9v lead) instead of the board’s positive ground pad? In that case it seems like nothing would be connected to the board’s positive ground other than the footswitch… maybe that’s ok?
I’m definitely overthinking it, and it turns out I probably don’t have to worry about the audio jack sleeves in a PNP battery-only pedal causing issues with NPN pedals elsewhere in the effects chain; this article helped clear some things up: https://www.amplifiedparts.com/tech-articles/pnp-positive-ground-pedalsWhere are you proposing to connect the positive battery lead in that scenario? You're overthinking this. Just use Figure 6 from that page rather than trying to reinvent the wheel.
I built this ultra-basic common-emitter amplifier based on Scherz and Monk's excellent 'Practical Electronics for Inventors.'
Some parameters: 1mA quiescent current, biased at ~9V, -100 gain in mind. Consequently, it has some slightly quirky values (20V, 74R, and so on).
Currently (!) running it at 18V, subbed 220n for the original 330n and 68R for the 74R, A100k pot as a volume control, and using a 2N1304 Ge transistor (hFE = ~40). I added a 100uF cap and a 100n for power filtering, idea cribbed from our favourite PCB designs. I'm still experimenting with this 'boutique' variantbut it actually sounds quite decent on Tele and P-Bass both as a basic clean preamp.
This might slightly address your original question, @rossbalch, regarding how to deploy low gain Germaniums. While I haven't tried to adjust this for PNP variants, I imagine that one would reverse the power and the associated filter caps. I also have a fair number of low gain PNPs (around 30 or so), so might be worth a shot.
It's refreshing to work with something so simple which does its small signal job with some aplomb.
Incidentally, I'm trusting that publishing this schematic to a closed site does fall under fair use. If not, I'll gladly take it down. It would make this entire post largely pointless but I respect the effort the authors put into this highly recommended book.
So, I was struck by your original question: how best to use low Beta Germaniums, which has sparked a renewed interest in the circuits I started with some seven years or so ago. I've since breadboarded various PNP Germanium circuits (Joe Gore's Rangemaster variant known as the 'Fiendmaster,' JHS Zonk II). These use between one and two transistors.Nice! I wonder if bootstrapping and/or negative feedback can help stabilise low Hfe Ge Transistor circuits. I'm curious eventually to make a cascading preamp design similar to the JFET amp simulators and see how it sounds.
For the Zonk mkII I used an OC75 (Beta @ 90) and AC128 (Beta @ 38), both with slight leakage. I like the sound (very 60s rock, Yardbirds et al.). I'm curious to see how a low gain Q1 will affect things. Will keep you posted (if you like).
In any case, thanks for the question, right up my alley since I have a number of low gain PNPs with exactly these specs.
Go the other way with a Double-AA, eh?The other thing of course is, I'm not married to 9v. Using an external supply and an LT1054 means that anything up to 15v is possible, not sure how that affects things but maybe it will help these lower beta devices be more useful.
