Big Monk
that’s a great quote…
Don’t feed the troll.
Tell me more... because I have a new DL4 mk2 and I hate it... Whenever I turn it on it adds an unwanted boost and a low mid thing... I have no clue how to make it stop, and I was so pissed at this brand new, $300 pedal that I threw it off my board and put my 20 year old original DL4 back on insteadHe has a very specific design philosophy about buffers. I think it’s possible that, back in the day, tone suck from very long cables was a real pita and he certainly solved that problem with output buffers. To some extent I don’t think he’s totally wrong: I have definitely experienced issues with modern built unbuffered pedals, things like the tone changes if you turn a delay (typically buffered) on after a drive which is caused by the drive having high output impedance and tone sucking when the delay is off and then the delay “fixing” that when on. That can cause serious problems for touring musicians, which is definitely the audience (I’m not one of them!).
The DL4mkII does have options for true-bypass and analog dry-through that might be worth tryingTell me more... because I have a new DL4 mk2 and I hate it... Whenever I turn it on it adds an unwanted boost and a low mid thing... I have no clue how to make it stop, and I was so pissed at this brand new, $300 pedal that I threw it off my board and put my 20 year old original DL4 back on instead
Looking at the specs sheet of the tl072 I also came to that conclusion when I first started looking into buffers (not that I had the knowledge to really make such an assertive claim to other people - I still don't hahah). What's you're opinion on the TLE2072?As usual, I am of the strong opinion that TL072 has no business being in a top notch guitar buffer in 2023. It's just too noisy at 18nV/sqrt(Hz) (same as the thermal noise of a 20k resistor). I would pick something with less than half that noise. And of course, it would also have to have very low current noise to do well with high impedance sources, so either JFET input or super beta bipolar (my new favorite). My best suggestions as a guitar buffer: OPA205/206/207, OPA145. Or, if you have all the money and want the quietest possible op amp that can handle high source Z, get an OPA827, or even two of them in parallel if you're nuts (I am, and I've done it).
TLE2072 looks like an easy drop-in upgrade over TL072, but I find it stupidly expensive for what it is. If you're going to spend 10x the price of a TL072, then might as well get a much better OPA2205. Only downside (for some) is that it's SMD-only. SMD is not hard, though. Just get the right tools and embrace the damn thing, else you'll get trapped in the past.What's you're opinion on the TLE2072?
Agreed. That’s how I do it and it works slick.Honestly, for me, SMD is fine even with moderately good, standard soldering tools. No need for an SMD soldering station, hot air gun or solder paste. As long as you have a relatively fine soldering iron tip available, I don't see why anyone can't give it a shot. Thanks for the info
If you just have to use through hole parts, I've had excellent results in my bass preamps with LT1113 and LT1169. But the price has more than doubled in the last few years, and I've never tried them with a low-ish voltage single sided power supply. But as you say, best to move along to SMDs, and buying some tweezers and a few $6 soldering iron tips is hardly a big deal, IMO.TLE2072 looks like an easy drop-in upgrade over TL072, but I find it stupidly expensive for what it is. If you're going to spend 10x the price of a TL072, then might as well get a much better OPA2205. Only downside (for some) is that it's SMD-only. SMD is not hard, though. Just get the right tools and embrace the damn thing, else you'll get trapped in the past.
OPA2992 is about half the price of a 2205, same noise spec at 1kHz, but much worse below (CMOS process). It draws 10x more power (!), so it never even made it past my parametric search, since I really care about battery life in my designs.I did get a bunch of TLE2072 chips for a much more reasonable price a few years ago. The OPA2992 seems like the more reasonably priced opamp that meets your 'requirements', JTEX. May I ask, how did you get from the ~5k DC resistance thermal noise to the figure of < 10nv/sqrt?
Resistance (ohms) | Noise Density (nV/√Hz) | Noise Amplitude (dBu) @ 20kHz BW | Output noise after 50dB of added gain (fairly typical for heavy metal distortion) |
1000 (NE5534, DNU as guitar buffer) | 4.0 | -123 | -73 |
2000 (~NE5532, DNU as guitar buffer) | 5.7 | -120 | -70 |
3000 (OPA2205) | 7.0 | -118 | -68 |
5000 (single coil pickup) | 9.0 | -116 | -66 |
8000 (vintage humbucker) | 11.4 | -114 | -64 |
16000 (hot humbucker, ~TL072) | 16.1 | -111 | -61 |
250000 (500k guitar volume pot @ 50%) | 63.6 | -99 | -49 |
I long ago stopped even looking at anything from Analog Devices/LT due to their outrageous prices. Hard to believe they actually they sell any, unless it goes on a satellite or something.If you just have to use through hole parts, I've had excellent results in my bass preamps with LT1113 and LT1169. But the price has more than doubled in the last few years, and I've never tried them with a low-ish voltage single sided power supply. But as you say, best to move along to SMDs, and buying some tweezers and a few $6 soldering iron tips is hardly a big deal, IMO.
I like your process my friend. Very thorough. The noise of a TL072 really is relatively high there. I assume the NEXXXX opamps should not be used as a buffer due to both of their rather low input impedance figures. Where, then, would they be suitable for use in guitar effects? I've seen people mod their old Boss graphic equalisers with NE5532 opamps, I must assume the current draw is some horrendous.OPA2992 is about half the price of a 2205, same noise spec at 1kHz, but much worse below (CMOS process). It draws 10x more power (!), so it never even made it past my parametric search, since I really care about battery life in my designs.
Thermal noise figures came from my trusty Excel speadsheet calculator:
Resistance (ohms) Noise Density (nV/√Hz) Noise Amplitude (dBu) @ 20kHz BW Output noise after 50dB of added gain
(fairly typical for heavy metal distortion) 1000 (NE5534, DNU as guitar buffer)4.0 -123 -73 2000 (~NE5532, DNU as guitar buffer)5.7 -120 -70 3000 (OPA2205)7.0 -118 -68 5000 (single coil pickup)9.0 -116 -66 8000 (vintage humbucker)11.4 -114 -64 16000 (hot humbucker, ~TL072)16.1 -111 -61 250000 (500k guitar volume pot @ 50%)63.6 -99 -49
LT used to be very generous with free samples.I long ago stopped even looking at anything from Analog Devices/LT due to their outrageous prices. Hard to believe they actually they sell any, unless it goes on a satellite or something.
Looking very good. It was off my radar due to my low power budget, but if that's not a concern, then at first glance it seems to be a terrific op amp, especially when considering the price. It's not even that power-hungry. Input offset is not a factor for our audio purposes here. Great find!How about the OPA1678?
I have heard this... I tried to consult the "manual" (pdf only), but it is kinda tech-speak. I admit, I'm a dumb hillbilly, and when it comes to "stop playing, hold this button, and while holding this button, push this combination til this light flashes, and now you will be in such and such mode... from there, release this button while pressing this other button until you get three flashes, then hurry and turn this knob... blah blah".The DL4mkII does have options for true-bypass and analog dry-through that might be worth trying
