jaminjimlp
OK I got all the supplies to build the board and got it done forgot to get the charge pump IC and it came in and powered the board up and could not get the power to read right so I connected a LED to 3v connection and nothing connected it to 5v and it has a steady flash after checking all the components orientation I found 1 cap (by the 3v reg closest to the 5v reg ) backwards... LOL so I changed it and still the same result. I am not a rookie at this stuff and I quadruple checked everything the cap backwards was a 4am thing LOL... I guess maybe I've fried the reg's and I even removed the charge pump IC and still no change. now the fuse that was used in the link was out of stock but Tayda had one with the same specs but different brand that's the only thing that is not exact as far as parts goes . so anyone have an idea were to start? Oh yeah with the CP IC in I get only 9v on the 18v taps.
One for the suggestion box:
I would like to see a LED power light and a Bypass \ Effect LED added to the board in a future revision, just my 2 cents.
