Asdrael
I love my WIMA caps. iirc I made it so signal only goes through polypropylene too cause I am a snob. I tried avoiding axial caps here because my self imposed constraint was a small footprint (so it fits on my deskAhh good choice on the Wima caps. I have FKP1, MKP10 and MKP4s here. I've also got Vishay axials in the turret board JCM.
How much space do you have under those large power resistors?
Any resistor that could see more than 1W is installed 1mm high - or should be- and everything I could has been installed with 90degres kinks on the leads just in case.
As far as I could measure it the insides stay coolish - the main culprit for heating would be the LM317. The heatsink I chose is oversize though so no problem so far. I still could likely cook breakfast crispy bacon on those KT88 holy hell.
Crunchiest distortion ever. Breaking it in, knowing how to dial it in better and for me changing the tubes made the top end slightly smoother and the low mid more present. I love it.that crunch![]()
