Wiring question for Paragon
Ok so I’m finally building a Paragon pedal, I’m super excited, currently waiting on parts I didn’t have just on the bench.
I saw this incredibly clever mod by @jubal81 utilizing a 2p4t rotary switch in place of the pairs of dip switches, so I have my rotary switches and thought I’d just figure it out but it’s breaking my brain, could anyone help me with a diagram of how I can wire them?
Thank yall ahead of time!
-JHK
You can use a DPDT on/off/on toggle switch instead of the dip switches. The switches in the KoT allow for 4 possible combinations, but the manual only describes and intends use of 3 of them - soft clipping (one switch up), hard clipping (other switch up), or no clipping (both switches down)
Because of this, you can set the wires that go to the down position of dip switch 1 and 2 to both middle lugs of a DPDT on/off/on toggle switch, and then for the other two wires, the soft clipping goes to the lower lug on one side of the switch, like the bottom left, and then the wire for the second part of the dip switch goes to the opposite lug, say the top right.
In this way when the switch is in the middle position, neither the lower left nor upper right wires are in the circuit, which means no clipping diodes are in effect. When the switch is toggled down, then the wire in the upper right is connected (hard clipping) and when it's toggled up, the wire in the lower left is connected (soft clipping).
It's important that the switch is an ON/OFF/ON, as any other kind of DPDT won't work for this
I explained the details of the dip switch as switch 1 and 2, meaning the first and second sliders of the dip switch as they effect one half of the KoT. The 3rd and 4th sliders control the other half, and are a copy of the first half.
Here's mine to show how I wired my switches
Sorry if I’m this comes off as sounding thick, but my intention was to emulate this build.
My confusion is coming from how the 4 terminals attach to the 4 way rotary, the rotary always confuses me I had used one prior to make a multi Cap switcher for my Wah but it’s in replacement for one component, so the mixture of the two switches I think is the hitch is for me.
Thank you for your patience,
-JHK
Oooh ok hold on yes thick as a brick
So,
The 4 positons are
No clip
Soft clip
Hard clip
LED clip
I didn’t realize there was an LED clipper in there!
Love this even more
I’m still a little confused as to how to wire the board to the terminals of the 4 way but I get the 4th position now
So,
The 4 positons are
No clip
Soft clip
Hard clip
LED clip
Love this even more
The LED clippers are not in the original circuit. Their clipping threshold is very high so they are in the "no clipping" position and act more like protection diodes.
If you want to be sure to get the connections correct, you can buy the 2P4T switch and get out your digital multimeter. Use the continuity setting "often marked with diode symbol" to find out which pins are connected in which position.
Turn the switch fully counter clockwise and find which two pins correspond to the switch poles in that position. That is "position 1." This is a good little exercise to get started understanding schematics. Look at the one above. The switch is divided into two number sections, one for each pole. "A" on the right and "B" on the left. The green wires show the connections and what's attached to them coming out of the switch.
When you're done, one pole connects to the feedback clippers and the other after the 1K following the opamp.
To mod the original circuit, just forget about the LEDs. For switch "A", connect the pole to the 1K resistor. connect the diodes to position 3&4. for "B" make the connection on 2&4.
Ahhhhh ok this makes heaps more sense!!!
I think I’ve got it or at least have a good idea now, but for clarification, dose that mean that the 4th position is a dummy switch?
That is to say:
Hard clip
Soft clip
LEDs
Nothing?
Ok I think I’ve got it now, dose this look right?
I have to visualize it as component and wires.
I included a blank version incase I’m that far off lol (ignore the pink highlighter it was used to mark what I had on the bench already and what needed to be ordered)
Thanks again for all the help, I love the efficiency of this mod and I’m glad I was able to pick your brain about it.
