y-u-no-f800b
So I'm putting together the Woodpecker (hummingbird) right now and figured that before I box it up, I should look into some minor mods. I came across this mod in a build doc from pcbguitarmania, where an led is placed in parallel with R10 in the schematic below, which seems to correspond with R6 in the pedalpcb build doc. However, the component values between these projects differ, so I wanted some advice before I potentially (worst case scenario) fry a $3 2n6027. (I am a cheapskate)
ALSO:
•Would the polarity of the led matter?
•The build doc says this affects the led can "add color to the tone" or change the behavior of the rate. Would it be worth putting it on a switch?
			ALSO:
