With a Buffer in front which is how my Pedalboard is set up, it sounds Great!!!
Direct from Guitar to Amp, there is a Screech when the Gain pot is maxed out But I would never use that much Gain.
I have since changed out the 12AX7 for JJ ECC82 ( 12AU7) and it still has plenty of Gain on Tap!
It is a Very Tight PCB build & I used a 1590Q Enclosure which allowed me to use top mounted jacks.
If any update is found, I may revisit!!!
