X
music6000
This was built a while ago & was detailed in a seperate thread with Top Jack mods.
I have listed here as sadly, Skidmark Pedals Cees van Eijk has pased away. R.I.P Dutch66
He was great to interact with & I had planned to build his Sonomatic.
Here is the Build report on the Tonitrus Bass Overdrive.
You can read my post's above about converting it to Top Mounted Jacks.
It's a Cool soundiing pedal & I'm only using it on Electric guitar & with the Foxrox Octron.
The Gate is different than what I was expecting, it leaves a low sounding Pop at the end of notes & chords when it stops from recieving a signal & varies when set to different settings but it's there.
It is by Design so I have modded the pedal so I can switch the Gate in & out of the circuit with a mini toggle switch above the Input jack.
This gives you an option to use a dedicated stand alone Noise Gate.
Tonitrus means THUNDER!
