That would be great. AionFX sells matched sets of 2SK208’s (which apparently have near exact specs as 2sk308A’s), as well as unmatched for a bit cheaper:Anyone have thoughts on if 2SK30As would be a good sub for the now-unobtanium 2N5952s? That’s what was used in the Boss PH-1, which is pretty damn similar to a phase 90. They’re readily available for cheap as SMD units, so they might be a good solution for finding a cheap and reliable option.
That matched set would definitely be an easy and cheap option. I planned on just getting 100 2SK208-GRs (which as you mentioned are identical to 2SK30A-GRs, just in a SOT23 package instead of TO92) from Digikey, and ordering a panel of SOT23-TO92 adapter boards from JLCpcb, but the Aion set is probably a more practical (albeit a bit more expensive per unit) optionThat would be great. AionFX sells matched sets matched sets of 2SK208’s (which apparently have near exact specs as 2sk308A’s), as well as unmatched for a bit cheaper:
2SK208-GR, matched set for phasers
This is a matched set of 2SK208-GR JFETs for use in phasers such as the BOSS PH-1r, pre-soldered to adapter boards for through-hole applications.aionfx.com
