Hi guys!
1st time posting a thread here and english is my second language. I read and used the forum before for troubleshooting other PedalPCB projects, but I can't find anything that helped me on that one. And my approach to pedal making is a "Paint by Number" one, meaning I follow instruction, don't have a clue the reason why I'm doing things, really. I have a multimeter with which I can use continuity and check caps. I finished 15 pedals, including an Electrovibe and an Hydra, all working. Some I've troubleshoot and then got to work. But this one...
SO! The problem is this: pedal off, true bypass works, clean sound is heard. Pedal ON: LED lights up when on, no sound. I hear a click when I switch the Stages toggle, but nothing else, no sound. I fiddle with the trimmer, which I assume is to calibrate the wet volume (?), nothing. My diodes aren't tripped. I got my 4 matched 2N5952 from GuitarPCB. My wiring looks good to me. Any help is appreciated. Have I build an expensive MUTE button? lol
Hope you guys can help me!
Thanks!
Thanks!
