SOLVED XC phase not phasing
Grazza
Just finished this pedal but there is no phasing. Definitely sound, and there is a sound difference when the switches are flicked but no phase.
I just read another post with the same problem but I'd love some eyes on it in case I missed something else. Here's what I've tried:
Started with matched quad of 2n5457s and a 2p200 instead of the 2n4125. Turned the 5457s around in case they needed to be the other way and nothing. Swapped the 2p200 for a 2n3906, nothing.
Swapped the 2n5457s for 2 matched pairs of the right transistors in as the silk screen says with the 3906. Nothing. Swapped the TLO22 for another and changed out the TLo72s. Nothing.
Will try everything again and maybe I haven't turned the trimpot slow enough.
Is there anything else I'm missing or doing wrong?
Solder bridge, IC 2 pin 6 and 7 or maybe it was the resistors next to it, must have done it when i did the repair and missed it. A bit embarrassing really. Pedal works great now though. Thanks for all your help. Two more left to trouble shoot. Had a bad run lately. Generally they always work first go.
