mkstewartesq
A couple of questiosn for those who have built the XC Phase. Since my components all seem to check out and my voltages seem roughly in line with what others have reported, I just wanted to determine if what I'm experiencing is actually "expected behavior" before starting a thread in the troubleshooting forum for what may be a non-issue.
1. On my 250K trim pot for biasing, the space where the sound actually phases is TINY - i.e., maybe a millimeter. About half of the throw is "no phasing", then a millimeter where it is phasing within which to adjust, then back to "no phasing" for the rest of the throw. Is that others' experience?
2. As others have reported with their builds, my phasing is subtle (at least on clean - when run after an OD, it's fairly noticeable). But I'm a novice with phasers so my expecations may be out of line. But have others had difficulty setting a bias that wotks for both stage settings? My block and script settings sound pretty good on 45 (Stages switch to the left) but on 90 both are much more crunchy rather than phasey. But given the tiny area in which to adjust the trim, I'm not able to get the 90 stage setting to clean up - at least not without throwing all of the other settings out of whack.
Thanks,
Mike
Thanks,
Mike
