How do I? 2 pedals but one is a kliche' and has it's own breakout?
swelchy
Working on putting an SHO boost in same enclosure with its own stomp switch into a kliche' build.. I dont need an order... just "sho" into the kliche'.. The kliche has it's own breakout board so how do I wire it? I tried wat I thought was correct and no go.
Input Jack to SHO's "jack input", SHO's "jack output" to Kliche's "jack input", Kliche's "jack output" to Output Jack.
If you need to find an é, Google "acute accent" and copy/paste from the results. There are keyboard shortcuts but they're different for every OS.
I added the Magenta wire to show the missing connection. This ensures the SHO is properly grounded.
(the GND on the switch-PCB is an input for ground, not an output for ground, so you need another ground source for the SHO-PCB)
