Black Water - Low Tide
Bio77
So, I've wanted to build this for awhile, but I was really turned off by hearing that it was a subtle effect. I finally got the LFO section breadboarded and was able to find that lowering the C38 value increases the depth range of the modulation. In my build I went with a 47n cap, but I think I might have overshot it, I'm thinking the 82n might have been enough. I also toyed around with shorting out the first half of the slew pot. On the scope it seemed that it was killing the modulation as it is turned up, but in the functional unit it seems to work fine. At full CW it sounds like a regular chorus, towards CCW it sounds like a warped chorus and at 50% more square wave character. I dialed in the gate as described on the forum, I am getting some pretty heavy hiss on the last 1/3rd of the pot, which maybe could be dialed out with an adjustment, but the rest of the range is very usable. I might just call this one done.
Enclosure is no-film on a Tayda powder coat. The Black Water is in reference to @thewintersoldier appraisal of this circuit :p I've only played with it a little, but for now, I think it's pretty cool and definitely unique.
Great build all around! Artwork and circuit work are killer as always. I’d been following the modification threads. Glad to hear you worked it out. Was there any change when you shorted the first half of the SLEW control in practice? That block is the heart of the circuit and does seem to have some shortfalls. I may need to revisit my build.
Thanks! There is a change but it didn't strike me as being superior. You can try this for yourself pretty easily. I have some alligator clip wires, I just connected pin one and two of the upper pot leads (the ones closest to the Attiny).
That looks great! I love the classic movie monster theme. That's one of your hallmarks, kind of like Marvel for thewintersoldier...
Hey for clarification the mod that you mentioned does it affect the randomizer pitch depth or just the mn3007 chorus depth?
Thanks Bret! I do like a spooky pedal from time to time :D Incidentally, the trannies you sent for the Dizzy Tone are in a spooky box, too. Just need a few finishing touches before I post it.
The randomizer signal is fed into an integrator op amp stage. The mod increases the amplitude of the signal out of that.
I found 1 setting that was to my liking and was usable, but i never liked it with overdrive or distortion and the the deal breaker for me. Youtube demos doing their thing as usual to make everything sound better than it does. The clone theory can do this sound better than the shallow water imo.
I don't think this thing is making it on my board but it's a pretty interesting idea. I got into it and learned some stuff. But even without the internet hype the premise of this thing is already an oversell.
A) We've got a randomized LFO controlling a chorus with a slew control that is sent into a LP envelope filter
B) Whoa, how does that sound?
A) Subtle
:ROFLMAO:
I appreciate the honest assessment of the sound. I was interested in the concept but the demos weren't doing it for me sound-wise really. For me modulation does have to work with OD or fuzz.
This looks awesome!! I've had this one on my list for a bit now (definitely working my way up to it). What kind of DC jack did you use? And did you just strip wires all the way to connect the 3pdt PCB to the board itself?
