Sourcing LM308s?
FWIW . . . . this is a list of single opamps I've been compiling over the past few years . . . .
Single Op Amp PIN-FOR-PIN Equivalents/Replacements with Slew Rates & Input Types:
CA3080 - Slew = 50V/µs (OTA); BJT
CA3130 - Slew = 10V/µs; MOSFET (In & Out)
CA3140 - Slew = 9V/µs; FET
LF351N - Slew = 13V/µs; FET
LF356 - Slew = 12V/µs; FET
LM201 - Slew = variable; BJT
LM301 - Slew = variable; BJT
LM308 - Slew = 0.3V/µs; BJT
LM148 - Slew = ~0.5V/µs;BJT
LM4250 - Slew = variable; BJT
LM709 - Slew = 0.25V/µs; BJT
LM741 - Slew = 0.5V/µs; BJT
LM748 - Slew = 0.5V/µs; BJT
MC1439 - Slew = ~6V/µs; BJT
MC33171N - Slew = 2.1V/µs; BJT
MCP601 - Slew = 2.3V/µs; MOSFET (In & Out; 6v MAX)
MCP603 - Slew = 2.3V/µs; FET
MUSES03 - Slew = 35V/µs; FET (very expensive)
NE5534 - Slew = 13V/µs; FET
NJU7031 - Slew = 3.5V/μs; FET
OP07CP - Slew = 0.3V/µs; BJT
OPA134 - Slew = 20V/µs; FET
OPA602 - Slew = 20V/µs; FET
OPA1641 - Slew = 20V/µs; FET
TL061 - Slew = 3.5V/µs; FET
TL070 - Slew = 18V/µs; FET
TL071 - Slew = 13V/µs; FET
Slew-Rates below ~0.4V/µs are often detectable by the human ear. Above 0.5V/µs, all bets are off for human ear detection.
The input type has bearing also as it affects the input impedance of the device. BJT - low impedance; FET - high impedance.
CA3130 - Slew = 10V/µs (OTA); FET
MCP601 - Slew = 2.3V/µs; FET
CA3130 - not an OTA, MOSFET input & output
CA3140 - MOSFET input
MCP601-MCP604 - MOSFET input & output. Rated for 6V max. Do not run them on 9V.
NE5534 - BJT input
BJT vs. FET input also affects input bias current which affects in-circuit offset voltage.
The opamps that have external compensation caps can have their SR reduced by increasing the comp cap.
It's not just about SR. When opamps are driven to the rails, some of the internal circuitry saturates and how it recovers from saturation can vary significantly from one part # to the next. This is not specified in the datasheet.
So this mojo means we are absolutely not in Kansas anymore? Or Boston?
No, man, you're in Chilliwack...
or maybe Toronto...
No, not ...
Nor ...
NE5534 - BJT input
Thanks for the corrections.
OP, are you in the states or Europe, or elsewhere. If you are in Europe I might know a guy that has some metal can ones.
