Grubb
Happy Easter folks! I had some free time on Easter Sunday, so I got out the Six String Stinger board I've been waiting to put together. The build went fairly smoothly, although I need to get more solid core hook-up wire or some pre-tinned stranded, as the stranded I was using was annoying and fiddly. I used diode legs to jumper the LED and CLR spots on the PCB as I prefer to have those on my footswitch breakout board. This was also my first crack at SMD soldering and it went really well. Phew!
This thing sounds FAT! I'm chuffed with it. Really beefs up a single coil and turns my chimey Vox clean tone into a creamier, richer sound. I like what it does to the top end, and the slight grit it adds. It gave me that feeling of wanting to play more, which is always a good thing
I really want to try this pedal as a preamp straight into an IR.
Here are the pics you probably scrolled straight down to:
Gah! I forgot to push the OUT wire back across with his buddies.
