Madbeans Flunkee: Wee Widdle Envelope Filter
jeffwhitfield
So, this little project started due to an open spot on the bass guitar side of my pedalboard. I have room for a mini pedal so I figure I could stick something there that could prove useful over the long run. Initially, I thought I would put an octave pedal there but couldn't find anything that I was happy with. Tried an MXR Classic Bass Octave...but wasn't happy with the way the Oct 2 tracked. Kinda was useless. So off I went in search of a good mini pedal for bass!
After a bit of searching, I arrived at the Madbeans Flunkee, which is a clone of the DOD FX-25. I have a Source Audio C4, which does have some killer envelope filter capabilities...but it isn't always on my board. So I figure a simple envelope filter would do nicely in that open spot. Like Madbeans says in the documentation, "If it's good for Flea..." :P
The build went really smooth given that one of my previous builds was a Madbeans mini fuzz pedal. I knew going in that things would be super cramped so I did my best to make sure all components laid as flat as possible. I also knew that the PCB would likely be making contact with the enclosure and other stuff so I wrapped it in non-conductive tape after finishing it.
This past weekend, I went to a guitar show here in Dallas and picked up an actual FX-25 on the cheap so I could A/B my build against it. Kinda fun actually trying out the original pedal. My build sounds pretty much identical to the FX-25. Only thing different is the Sense knob works a little differently. Seems it's flipped on the FX-25 (turning it up increases sensitivity as opposed to decreasing with mine). I'm actually ok with that since I would prefer that turning down Sense results in me required to play harder to trigger the envelope. I also noticed that the Sense on my pedal has a wider range. With the sensitivity all the way up, the FX-25 doesn't want to trigger, whereas it triggers on mine with a heavy handed note. So, yeah, mine sounds the same...but strangely works a bit better. Go figure!
Overall it sounds really good and is a nice addition to the pedalboard. :D
Wow, what a squeeze!
I cheated and put mine in a 1590B..
I know, right? I did a Fuzz Face prior to this one and didn't think it would fit...but it did. Just have to build the board carefully and not go over a certain height. Super tight with this one though. :P
