Thanks! This was the most complicated one I've done, so far. I planned to use the space between the PT2399s as routes for the power, but I forgot that since they are SMD I would need via to connect to the back copper layer for the signal traces. It was a nail biter in a couple of spots, but I got everything crammed in. We'll see if it works, this weekendThat is a super tight looking layout @Bio77
It looks great!
That looks pretty good, where's the struggle?I'm interested to go down the SMD route and there's been loads of inspiration here recently so this is my 4 clipping options rat pedal and JFET boost circuit. Also, does anyone have any good tips for SMD layout? I find I struggle way more than with through hole designs.
A lot of the tips for through-hole boards apply just as much for SMD,does anyone have any good tips for SMD layout?
Any reason for not using a copper pour for GND?Here is where I landed with the final layout on my "The Fuzz":
Yeah I do similar, set it to "unpoured" so that I can see things well. Also handy when checking the 3D model.I removed it so the pictures would be clearer.
Piece of cake on through-hole, just "surface-mount" the resistor leads between the two points that need to connect. On surface mount it can be a little trickier, but if you have a pad that at least one side can go to you can solder down one side then "float" a wire to the other side to connect to where it needs to go. When I tack on SMD passives like that I generally apply a dab of epoxy (or hot glue in a pinch) for strain relief, just in case.So I borked up a build I am working on using one of my own boards. When it didn't work I started troubleshooting, but my troubleshooting turned up no clues. In going back to my Diptrace files and the original schematic I was working from, I can see that I accidentally left out a 1K resistor going from Vref to a net of capacitors. To fix this pedal, I will need to physically connect the Vref net to one of the caps via an offboard 1K resistor. Can anyone recommend a good way of attaching/soldering an offboard resistor? Preferably under the PCB
I got my proto boards of this in, and it sounds awesome! The ghost feature is pretty cool, and I still plan to try it out with a MN3008 in the second position to give some more rhythmic delays.Due to the bad influence of others on this forum, pushing me to explore this more, here is something I finished up today. It is a 2 BBD delay, giving 600ms of delay time in a 1590A. This has a charge pump to drive the BBD's at 15V, and I added a switch to tap into the first BBD, hopefully giving a sort of rhythmic delay.
 With the little work of hand soldering an IC and 3 SMD parts to the top, I'll be able to have 600ms delay and modulation, pretty cool!
  With the little work of hand soldering an IC and 3 SMD parts to the top, I'll be able to have 600ms delay and modulation, pretty cool!Dan, you and thomasha are headed to the Thunder-dome!I got my proto boards of this in, and it sounds awesome! The ghost feature is pretty cool, and I still plan to try it out with a MN3008 in the second position to give some more rhythmic delays.
I did have one issue, I forgot to ground the compander! After connecting it to ground, it works like a champ. Stupid mistake. So while I was updating the board, I thought to myself... there is no way I can add modulation, right? Right? Well, a little work later, and here we areWith the little work of hand soldering an IC and 3 SMD parts to the top, I'll be able to have 600ms delay and modulation, pretty cool!
I've did a few simpler layouts beforehand, but I've been sitting on them to save a few bucks on shipping. Also I never said any of them worked, so there's that. I'll keep my fingers crossed.@flemming I can't believe this is the size of the first project you're sending off! My first PCB project was an Em-Drive, it had about 10 parts total and it still didn't work properly
Nice work mate, I hope to see a future build report with this board.
I hate getting back coasters. The pricing structure at JLCPCB always makes me tempted to buy 15 or 20 boards even when the design isn't fully vetted yet.I've did a few simpler layouts beforehand, but I've been sitting on them to save a few bucks on shipping. Also I never said any of them worked, so there's that. I'll keep my fingers crossed.
Now I know who to direct my stupid kicad questions toI hate getting back coasters. The pricing structure at JLCPCB always makes me tempted to buy 15 or 20 boards even when the design isn't fully vetted yet.
I'm digging this thread and this forum a lot since pedals are mostly a new direction for me. The vast majority of my board layouts have been onboard preamps and the rest have been for various bass amp and preamp builds I've been doing over the last ten years.
So this would be a typical onboard preamp layout in my world:
I've been using KiCAD for about ten years now and tend to make and use my own component footprints most of the time. That particular board came from DigiKey's DK Red service, which is priced similarly to OSHpark but had a few different spec limits. Biggest difference is that they don;t accept plated slots, and that does matter to me a lot occasionally.
