Do you have the drilling guide for the Cannon Fodder MKI?
I'm following this as there are no build documents for it and it's been out long enough that I've ordered it and have begun to build it. Are the LED's supposed to be the non clear ones and 3mm with the Green and Red? Is there a drilling template that takes these into consideration or are they for the inside and used for clipping?
The red/green LEDs are standard brightness diffused LEDs. They're used as clipping diodes so aren't intended to be visible externally.
I'll get the rest of the info up for you shortly.
Here ya go. :)
Could the Drill Template be provided too? I was gonna try and combine a 3-Knob drill template with the bottom half of the Paragon Mini drill template but when I overlay the Dirt Dauber's PCB over the Paragon Mini PCB in Photoshop, it looks like the footswitch and LED spacing might be narrower
Yep, give me just a bit and I'll get it posted.
This is the first PCB designed to work with the SideEffect module, so you'll also have the choice of building it with a single footswitch that controls both sides. (Long press, Short press)
Don’t suppose this was still on your radar @PedalPCB ?
Totally understandable if you’ve been busy ofc, esp with the birthday contests!
