Robert
George Cloney
Could the schematic and/or BoM for the Dirt Dauber be posted? Hadn’t heard of the OG until I saw the Dirt Dauber, it sounds *epic*, would love to hit the ground running with it heh
Here ya go.
WHOOOOOP!!!Here ya go.![]()
I would be very grateful to have a peak at the fuzz mutant/mutagen schematic if it's in shareable shape—I'm really curious about his version of that circuit.
A gentle nudge...
I'm following this as there are no build documents for it and it's been out long enough that I've ordered it and have begun to build it. Are the LED's supposed to be the non clear ones and 3mm with the Green and Red? Is there a drilling template that takes these into consideration or are they for the inside and used for clipping?Do you have the drilling guide for the Cannon Fodder MKI?
Do you have the Caramilk secret?
Could the Drill Template be provided too? I was gonna try and combine a 3-Knob drill template with the bottom half of the Paragon Mini drill template but when I overlay the Dirt Dauber's PCB over the Paragon Mini PCB in Photoshop, it looks like the footswitch and LED spacing might be narrowerHere ya go.![]()
Don’t suppose this was still on your radar @PedalPCB ?Yep, give me just a bit and I'll get it posted.
This is the first PCB designed to work with the SideEffect module, so you'll also have the choice of building it with a single footswitch that controls both sides. (Long press, Short press)
