You are correct, I'm no expert but what you describe I know... Another point is the FV-1 does come with local program if you don't feed one to it. That's actually a troubleshooting technic I've seen here to exclude a problem with the EEPROM and confirm the FV-1 works and passes the signal.Again, major noob here open to being corrected, but as I understand it the FV-1 is the hardware/processor of the circuit and the EEPROM chips contain the program/software that tells the FV-1 what to do with the signal. EEPROM are a form of memory/storage chip, and they contain the algorithms specific to the effect. That’s why the different effects all need the same FV-1 but come with various different pre-programmed EEPROM chips.
I never soldered SMDs but according to your pen description is good for SMD so...Thanks for all of that. Very interesting.
I guess I’ll buy the board and give it a try. In the meantime I’ll be watching videos on surface mount soldering.
And just to be precise, is the flux pen I already have (linked above) good enough, or should I get a separate container?
Nope, non-polarized part. Just mind that you need to leave enough "leg showing" to be able to bend it over horizontally on the board.I am looking at the board and the parts for a Hydra build! Quick question, does the X1 Chrystal Oscillator have polarity? I'm not seeing any thing on the part or on the PCB to indicate polarity.
And hopefully this is the correct part, because it's what I bought:
How are you running it? (Signal chain I mean). Try running a buffered pedal before it and see if that helps. I had the same issue but I would not categorize it as "significant" loss of high end, just a tad for me and I'm not completely sure it's not my imagination. I would up building a dedicated buffered loop box to put the Hydra and Spatialist reverb is and it helps.I finished it. One thing, well 2 things:
1. It’s amazing!
2. I notice that the pedal rolls off a significant amount of high end. It that inherent to the circuit? If so, is there anything to replace to make it more “transparent?”
I guess it depends on how much "significant amount of high end" loss is. It should not be that way. Does the loss of high end still happen with the MIX knob turned all the way off?I was running it after several pedals, and right after a Boss GE7 (that has a buffer right?), but activating the hydra with out any of the head switches up is when I noticed it.
Can you use a Spdt on off on in place of a on on?Correct. You want 2-position (ON/ON) SPDT switches.
Up enables the head, Down disables.
