DigitalZombie
I laid this out on the breadboard to try it out, as I like to do if the circuit is simple enough. I'm having the same issue another user was with barely any sound unless you strike hard. I'm using all the correct value parts, and I even had some BC549B's lying around that measure around 315-320 hFE on a Peak Atlas. The same user suggested that this circuit is picky about transistor gain, but said he didn't have the ability to measure the transistors he used for Q1 and Q2. These are the voltages I'm getting:
Q1 c=7.14 b=0.631 e=0.01
Q2 c=0.352 b=0.649 e=0
Q3 c=0.056 b=0.6 e=0.07
According to the build doc of the Madbean LEFTA which I guess is closer to the original Os Mutanes, they used vintage transistors (didn't mention gain) but got somewhat similar voltages:
Q1. c=7.88 b=0.638 e=0
Q2 c=0.85 b=0.6 e=0
FWIW they use a trim pot on Q2c.
So has anyone successfully built this one and was able to measure their transistors?
Q2 c=0.85 b=0.6 e=0
