Paragon Mini with mods
markuus
Just finished this build this week, and absolutely love this pedal. Had never played a KoT circuit in person (I'm about 3 years down the list on Analogman's waitlist), but I understand why people love this circuit. Definitely a keeper for my board.
What do you think of blue and cream knobs? Kept the design as simple as possible while still evoking the KoT. I didn't use the color I intended for the Tayda UV printing so it's a really pale greyish color instead of gold, but still looks pretty nice.
I used a the "warmer" mods @ckaudioeffects documented here, omitting all the other mods (most of which aren't relevant/feasible for the Mini). I don't have any other KoTs to compare with, but it does sound warm and full with the modded values. There's a good amount of lower end without getting muddy, at least with my Tele.
(If you do the capacitor mods, don't do what I did and assume both channels are arranged in exactly the same way. C4 and C17 are in slightly different places on the PCB between the two channels. I missed that and placed two capacitors incorrectly at first. Including a diagram attach to this post in case it helps anyone else wanting to mod their Paragon Mini.)
I used 10k resistors in R3 and R20 as @MichaelW suggested (apparently the value in the original KoT) and used B250k pots in place of B100k for the two Drive pots per @Chuck D. Bones. With those values, the Drive knobs have really wide sweep from mostly clean to very dirty. So far, I'm liking having the right/red channel cranked and the left/yellow channel set to light drive.
I went with BA282 diodes in place of MA856 and 1N914 in place of 1S1588, and used DIP-6 sockets so I can experiment, though haven't had a chance to do that yet. So far, I really prefer the soft clipping at both higher and lower gain settings and currently have both channels set that way. I've got a bunch of the diodes people suggested on here, so maybe I'll like some other options for the hard clippers.
Awesome looking build, and I love the knob colors!
Funny, I just had mine out today after not touching it for months. Somehow it sounds different than my full size Paragon.
A bit meatier. Still loving it!
Would these mods also be good for PoT Pauper?
The Pauper is a different sounding pedal and doesn't really need those mods. The warmer tone mod really is the most beneficial for the full size Paragon project that has a strange anomaly that's been noticed by some folks (like me) in that it tends towards the bright side even though the schematic is largely accurate to the originals.
I just built this pedal with the same mods as the OP (thanks for posting them). Still getting used to the pedal and trying to figure out how to set up the DIP switches and treble/presence trimmer for optimal sound, but so far it seems pretty great!
I have this in my workbench but checking other documentation for example for the paragon std and the theseus from Aion, I see that there is missing one 1uf cap in parallel with the other 1 uf cap.
I guess adding the other cap in parallel or just adding a 2 uf cap will do the job? I mean I don't understand electronics really well but that what I think it will help..? perhaps having two 1uf caps will do something
ss from paragon mini.
SS from the paragon standard.
SS from theseus
I mean, am I wrong? or my idea is ok ?
SS from theseus
Maybe post the question in GENERAL QUESTIONS, with its own thread instead of buried in someone else's build report — that way more people will see it if they have a similar question but for a different build.
Since it's posted here...
Yes, two parallel caps will sum. So your two 1µ caps = 2µ.
Or just use one 2µ2 cap if you've room for it in your build (probably smaller than two 1µ caps 🤷‍♂️ )
The two 1µ caps or one 2µ2 cap will let more bass freqs through. You could do one 1µ then alligator clip a second 1µ to it in parallel to see if you can hear a difference and decide whether one 1µ is enough.
Looking forward to reading your build report about it.
Cheers,
FF
