Buddy's Pedalboard
BuddytheReow
Moderator
Hey everyone,
I am starting on the journey to build my very first actual pedalboard! What I currently have is a piece of MDF board that was taken from an old computer desk that my folks have in their attic. That's it, literally just a board. To counter my pedals from shifting around I installed cabinet bumpers on the bottom of them. For those that don't know, cabinet bumpers are pieces of rubber (about the size of a shirt button) that you will stick on the inside of a cabinet door or on the face frame to protect the two pieces when you close the door. These bumpers really aren't working on top of my Chinese power supply looking like an Octopus mess.
I've decided to document this project for others to enjoy or possibly be inspired. This is currently how my pedalboard flows and I think I'm going to keep this layout. Where I play, my amp is to the left of me. The green box is my power supply. As you can see this is kind of a mess to connect the bottom row to the top and I currently use a spare, coiled cable. This I want to incorporate into my new board.
I'll be building this out of some spare pine boards I have in my garage. The dimensions are going to be roughly 4" high, 20" wide end-to-end, and 14.5" depth. So now we have a rough shaped box to fill with my DIY creations. I want to give myself a new challenge so I am going to connect the board ends with a box joint using my table saw. Sure, I could just use a butt joint and throw some screws in there, but I want to try my skills at something new. Of course, I'll practice it using some scrap. The two rows for the pedals I'm going to throw some 5" wide boards in there and mount some velcro on. I'll probably just use pocket holes for that since I won't care what's underneath.
Now the electronics portion. I want to mount the power station underneath and will do that with some velcro. This board is just staying in my basement, so I'm not to worried about falling out while traveling. In from guitar and out to amp, I'm going to install some jacks on the sides to have a "plug and play" scenario. To connect the bottom row to the top, I'm going to install additional jacks and connect them with some shielded cable underneath. This way I can plug patch cables into the jacks to connect them.
Cable management: I've decided to use cable/wire clips that I will hammer on the underside. Cable ties may also be included here, but that's far down the line from now. I'll also have to drill out a hole for the power supply from the outlet.
If anyone's got any other ideas or what works/didn't work for you let me know. This will be my personal project over the next few weeks.
BuddytheReow
I've made a few and I like adding a power switch and outlet to them. This was a first attempt at a Schmidt style board mostly made out of an Ikea MDF table top. Had a roll of walnut glue backed veneer and used that to try to hide some of the crappy MDF edges.
View attachment 33431View attachment 33432
How tall is your board? Considering doing the outlet switch, but I don't think I have enough room. Plus, this is my first one and I can always make another one sometime down the road.
That one is about 4.5 inches. I did another one that is 2.5 inches thick and think that is about as thin as I would go. This one I spliced the outlet/switch straight into a 3 outlet power strip. I also cobbled together a box around the wires for safety. Not the prettiest job but it works.
Sigh...like I mentioned, I wanted to try my hands at a box joint. This was my first attempt on some scrap not very promising. Out of frustration I broke one of the "fingers" off. I went relatively quickly on the table saw which is why it's not level. I will try again with some more patience.
Alright. I'm convinced that I can't do this with pine. It's just too soft with a straight blade and I don't want to pull the trigger on a dado stack just yet. I took my time cutting, but it basically collapsed when dry fitting. I'm going to try just a simpler joint. I want to steer away from screws for the outside, so maybe I'll just use dowels.
A few fess fingers might make them a bit stronger and less prone to snap off.
Agreed 1000%. I've tried making these in the past by hand and they snapped off from my chisel. I think pine is just too soft for me to do this. I think my next one, whenever that is, will use some hardwoods like poplar or oak. That should clear it up and maybe I'll have a dado stack by then to make the fingers wider.
I have seen a few Youtube videos on making a jig like in the link below. Can be used to cut box joints without a dado stack.
Biting off more than you need to chew.
Make your three tines (& 2 spaces) into one tine. What are those, an 1/8"? I'm guessing based on your pics, but I'd go up to at least 1cm to 1.5cm (that's about 1/2" thick).
Draw out the tines on the board edge like it's a square wave. Drill a 1/2" hole every other square, jig-saw & file square the curved edges from drilling.
Of course you'll have to work out ahead which boards get the outside tongues/tines...
If Leo Fender's workers could do it with solid pine, dovetails be damned, so can you.
It collapsed while fitting it because you have the wrong grain orientation. You’d want to rotate each of the pieces 90° to cut the fingers so they follow the grain instead of going across it. It also looks like some of your fingers (specifically the top, broken off one, and the one 3 below it on the piece on the right) are a bit thicker than the slots, which will compound with each successive deviation and cause crowding— before fitting it together you’d probably want to check for alliggnent and carefully chisel or file away just a few thou off of the noticably too-thick fingers so they join with their respective slot more easily.
Screw it. I’m gonna go the pocket hole route. If you’re semi interested in making anything out of wood (shelves, cabinets) I would highly suggest picking up one of these bad boys. A simple pocket hole jig. Just clamp it on then drill.
Took some time this afternoon to put the main cavity together and drill out holes for the in and out jacks. I took a round over bit for my router and did the rest with sandpaper. Make sure to sand both sides pretty well with a medium then fine grain even if you’re going to paint it or leave it bare. “Shelves” coming tomorrow morning
