Harry Klippton
Not Interested
I tiled my bathroom floor last week and now it's fully cured so I silicone'd the base of the tub and put up some Sheetrock. I'm having fun but I'm ready to build some pedals again
I'm considering a pedalboard build myself. What kind of wood did you use? I've got a crap load of pine and a bit of plywood as leftovers.View attachment 33345
Got the frame for my new pedalboard glued.
Nice! I look forward to seeing the finished design.View attachment 33345
I used 1/2" poplar, to try to keep it lighter.I'm considering a pedalboard build myself. What kind of wood did you use? I've got a crap load of pine and a bit of plywood as leftovers.
Unfortunately not. I had no idea what the voltages should be and I can't afford OC75s so I chose transistors for a Fuzz Face (around 80/120 w/low leakage) but used values from the TB1.5 out of spiteDid you test with higher voltages in Q2? The MK 1.5 uses OC75 transistors so the voltage probably creeped up toward 8 vDC.
With 470r/8k2 unity was at 10. I tested it against my Dunlop JDF2 and JHF1 and those were louder (and quieter but they sound worse) so I went with 2k2 and now unity is at roughly halfway up. Perfect.With the 2.2k output resistor, where did unity gain end up on the volume knob?
Looks great!
First of all I play a Strat with low-output pickups set almost flush with the pickguard. My amp is basically a Princeton Reverb copy but it has a Clean/Drive toggle to go from Blackface to Tweed overdrive.You know, this is a weird one. I hear people talk about 470 not giving unity gain or barely so on the dial and I’ve never experienced this.
Often, I have to back it down to 220-330 or else anything past 3:00 o’clock starts to oscillate.
I’m wondering if it’s a clean/dirty amp thing? I’m running my amp pretty dirty with Fuzz.
I see. Do you have any idea why this fuzz face sags so much in my case? It sounds like it's overloading my amp. Something similar happens if I play say a fuzz face and a Foxx tone machine together. It goes SPLAT!That “smoothness” you hear is the fuzz complementing the amp overdrive. In reality, this is the classic fuzz overdrive sound we hear on many of our favorite live records of the late 60s/early 70s.
What I hear on a lot of builder demos and YouTube demos nowadays is Fuzz into clean amps. And per the conversation @Coda and I recently had on the forum, I don’t mean loud Marshall or Hiwatt “clean” or Twin Reverb clean (big, bold, loud, and with pronounced bass response).
In this case I mean truly clean, with some grunt but no true power tube overdrive happening v
In this case the graininess and fuzziness is the fuzz character itself.
I prefer the smoother tone of the classic loud, distorted amp plus fuzz but that’s what’s so awesome about simple fuzzes: Everyone likes to m for a different reason or is pursuing a specific sound and the circuits, although simple, accommodate all of that.
Standard MK1.5 I think.Which schematic did you use? The sagging is likely due to high gain and/or increased bass response overloading and heavily compressing and already compressed amp.
This one is staying as it is, worst case scenario I got myself a bass fuzz. But I'll definitely experiment with the values soon.OC75s are the brightest overall OG Germaniums I’ve ever played. Frankly, I don’t buy into transistor hype but the OC series, the 75s in general, have a “thing” with respect to treble response.
Also, the higher collector voltage of Q2 in a true MK 1.5 would contribute to an overall brighter tone than a standard Fuzz Face.
The input cap and higher emitter cap might have compensated for this in the original but are likely giving you an overwhelming amount of bass response in your circuit.
Try dropping the input cap down to 2.2u and/or the emitter cap down to 15u. If you need to reduce gain more, try 82k and 91k in the feedback resistor slot.
You’re one step closer to never having to pay for setup work again…..Welp I'm finally done. I think it came out good- the guitar plays great and it sounds good acoustically. I learned so much about how the nut affects the sound and playability of the guitar, so this was a great experience. I know how I can improve on the next one too.
Oh I never did to begin withYou’re one step closer to never having to pay for setup work again…..
Kinda like being married.....Oh I never did to begin with![]()
