Fingolfen
I've been kicking around a modification of the MXR Distortion+ (1980) version where I added a BMP tone stack to it, but honestly I was having some problems. It worked, but it was very poppy. It already had an input pulldown resistor, and while adding an output pulldown (I tried 100K and then 10K) did fix the pop, it caused the pedal to lose volume. I tried putting the tone control before the volume pot, but that caused it to lose even more volume (even though my BMP tone stack has a gain recovery stage). So I decided to first rethink it a little and see if I could get reasonable tone control (and better volume) messing around with some of the Wampler mods. I decided to leave the extra switches off for now, and just go with the base circuit with the added tone control and relocated gain control...
As you can see from the photo above, our resident technical expert Steggi has been hard at work getting this thing together. I don't have my full prototyping board together yet, so I'm making do.
The good news is... the thing fired up beautifully first time... Steggi is a frikkin' genius. I did have to reverse the volume pot, but that's a minor detail The bad news is... the tone control is still very subtle at best. I did read that someone had put a larger capacitor in series with the tone pot and got better response. I'm going to try it, but I'd love to understand a bit better why that might work...
... I'm also thinking about trying out replacing that pot with the BMP tone stack... just to see what happens... but that's for tomorrow...
