jeffwhitfield
Not too many new builds lately...but I do have a few personal ones to post. One of them is a bass pedal based on the Boss ODB-3. I read about the ODB-3 recently and, after listening to a few demos, it sounded quite interesting. I was about to just buy a used one to play with but, after a bit of research. found out about the N.E.W. Bass Overdrive PCB by GCI. I've looked at the stuff GCI but nothing perked my interest till now.
The build went pretty smooth...although there were a few hiccups along the way. First, I screwed up and ordered solder lugs for all the switches when the PCB calls for PCB pins for all of them. So I had to wait a few times for new parts to come in. Once everything came together, the only other part that threw me was the wiring of the foot switch to the PCB. The instructions actually point you to a different instruction sheet for the Brutalist Jr. I was able to figure it out, which wasn't too difficult...but for a newbie, this will most certainly confuse the hell out of them.
Once I built it and fired it up, I was half expecting it to not work. One of my previous builds of a bass overdrive, a Black Mirror VII from PCB Guitar Mania, didn't go so well. So, yeah, I wasn't hopeful it would work. Suffice to say my fears were quelled and I was stoked when it came to life in all it's glory.
Quite an interesting bass overdrive that imparts its own character. I have two other pedals that I use as my main bass overdrives: a Darkglass Alpha Omega and a Tech 21 MP40. The N.E.W. Bass Overdrive sounds quite different from either of them...which is nice cause it means I have another flavor for some bass tones. It's not as modern sounding as a Darkglass pedal...but not quite as "classy" as the MP40 either. It's actually quite neutral really. You can definitely get it to sound more modern or classic depending on how you set the EQ and drive though. Really an interesting bass overdrive all around. A part of me wants to get a real ODB-3 now to compare to it.
