NGD Squier 40th Anniversary Jazzmaster, Vintage Edition
andare
I play original instrumentals that are a mixture of surf, Italian soundtracks, fuzz-heavy instrumentals plus some funky vocal numbers and Isaac Hayes-inspired ballads. My main guitar is a Classic Series 60s Strat that I've modded to suit my own needs (bridge+middle replaced by bridge+neck, phase switch for the neck pickup, master tone, Jazzmaster screw in arm, flatwounds). A Jazzmaster seemed like the next logical step.
I had three options: 1) order a custom guitar from a renowned Polish builder (awesome but not cheap and not a Fender), 2) order a Fender Vintera (too expensive now and I've had terrible experiences with Fender's QC on Mexican instruments plus it might still need some upgraded hardware) or 3) get a Squier (still cheapish, much better QC IME and definitely needs upgrades but still way below Fender prices). A look around the usual forums and Youtube channels and a small sale and here we are:
I just love the colorway. I passed on a heavily discounted seafoam green because my Strat is cerulean blue and my main P bass is aged daphne blue - too many blue green guitars! This one set me back the equivalent of 490 Euros shipped.
It's a keeper!
The good:
  • the one-piece maple neck is straight, slightly rolled edges, the fretwork needs a polish but it's way better than any MIM Fender I've ever played/had
  • no fret sprout - none of my Squiers ever developed it, all of my Fender MIMs came with it
  • the neck carve is fat, thick front to back, thicker at the 12th fret, generous shoulders
  • really dig the satin finish, satin on the fretboard too like a Bronco bass, gotta be a first for guitars though
  • the nut slots are centered and the right depth
  • the truss rod works well
  • the neck pocket isn't the tightest I've seen (that would be my shell pink Bronco) but it's pretty good and angled
  • perfectly shielded and less single coil hum than my Strat despite the higher output
  • it sounds like a Jazzmaster - I love the pickups, the middle position is THE SOUND
  • it came detuned to D but already set up for E: neck relief, action, intonation are spot on
  • low action, no buzzes anywhere, no fret outs - haven't checked with a fret rocker (and I'm not gonna :) but it seems pretty level to me
  • the tuners are very smooth, on par with my Strat
  • the aluminum pickguard is straight
  • it only weighs 3.5kg
The so-so:
  • the neck is somewhat rough, feels like unfinished wood, easy fix with fine grit micro mesh
  • the nut also needs polishing but it seems to be real bone
  • one small black dot next to the 5th fret dot marker - can't see it when I play so it's fine
  • a couple of very tiny dots in the finish of the body, really hard to see but it's not 100% perfect - weird satin finish, slightly textured
  • the main volume knob seems crooked and drags a bit on the PG - easy fix
  • volume and tone seem to have a weird taper - but then again my Strat has CTS pots that do nothing until 2 then go up to 7 then very little, I think the JM uses a 33nF tone cap, which seems ineffective compared to my Strat's 100nF
  • the bridge hasn't sunk down into the body (yet) but the saddles have some sideway jiggle (just like every Precision bass bridge ever) but only if I move them
  • weird resonance on many notes despite the generous break angle courtesy of the angled neck pocket (no shim needed)
  • both switches have some play but they click nicely
The bad:
  • the vibrato is unusable right now. The arm clicks in the collet, the whole thing clicks when depressed and it vibrates sympathetically with some notes.
I suppose several of the above issues will disappear when I put on a set of 11-49s. I'm gonna open up the nut slots with Hosco nut files for 10-46 - should be good for a couple of gauges up. I'll see if the collet can be tightened or the knife edge needs to be cleaned up and rounded. If not I'll have to buy a Fender AV tremolo assembly for lots of money. It's currently on sale on Thomann too.
There are some horror stories out there like expensive MIA Fenders with off-center side dots, botched truss rods, chewed up fretboards, missing parts. Fender's QC seems to be the worst it's been since the late 70s. I think I got lucky with this one!
I "upgraded" the vibrato on my CV JM with a Fender Vintage Reissue, but had the same binding in the hole for the trem arm collet. I had to open the hole up a little bit with a round file. It looks like a beauty! Congrats!
thanks, that's why I'll try to salvage this vibrato before spending money
Nice, I’d been wanting a J.Mascis when I bought my Opal Jazzmaster. I like the bridge a little more on yours.
Honestly, it didn’t make a ton of difference. The stock hardware is fine on these Classic Vibes
The clicking and random vibrations of the arm are driving me crazy. If I can get rid of that there's no way I'm dropping 100 euros on the Fender vibrato.
