toddrace
My Deflector reverb build doesn't work the way I expect it to. Any Density knob position left of 12 o'clock produces a whine with a sort of bitcrushed static underneath it. (I have a nice movie of the noise, but it doesn't look I can upload it. There's a high-pitched whistle, which may be common as the knob spins, then underneath that there's a static that downs everything else out. Twist the knob back up and the static and whistle fades back out.)
Everything else seem just fine. If I stay above 12 o'clock on the density knob the pedal sounds sounds great. But is that how it's suppose to be?
I'm a novice pedal builder with about 10 builds under my belt. This is my fourth PedalPCB build overall (the Low Tide mini may never work without a schematic for troubleshooting, if anyone cares), and my second FV-1 build (Unison Double Tracker works great!).
It seems like this would be related to the the section on the schematic related to the FV-1 clock and the Density control. So I started there, beginning with the capacitor. Troubleshooting so far:
Any ideas from someone more experience than me greatly appreciated. Thanks!
[UPDATE] More, better lit photos if that helps.
- replaced replaced C14 (it tested fine)
- replaced R14, R15, R16 for good measure
- Swapped IC4 - CD4049UBE
- replaced Density B25k because why not (it tested fine, anyway)
