Just received this from Dunlop Tech, but I haven’t had any more time to mess with it this week.There was a thing with these not having static protection for the mosfets at one point, might be a good place to look.
I'm about to finish this one up. Build report coming soon
I mean the clip switch is closer to his knee than his groin. Also I hand drew that in inkscape from a reference. It's not a scan. The first of several designs I made featuring frog and/or toadLove this. You know... this one falls in the "unfortunate pedal art" category, right? "Is that a clip switch in your pocket or does your penis just drift to the right?" To be fair, drilling 10 holes into the face of an enclosure makes eclipsing a groin pretty likely.
When drawing by hand im guessing you have a stylus and a tablet/comp to support it right?I mean the clip switch is closer to his knee than his groin. Also I hand drew that in inkscape from a reference. It's not a scan. The first of several designs I made featuring frog and/or toad
No, with a mouse on my laptopWhen drawing by hand im guessing you have a stylus and a tablet/comp to support it right?
Awesome! I was hoping i wasnt going to have to spend moneyNo, with a mouse on my laptop
Who are we to say that Toad isn't indeed packing? And cursed with a severe right angle bend? That strangely clicks into place?I mean the clip switch is closer to his knee than his groin.
I remember telling you to rename that switch and swap the p with a t.I will not permit you to malign my beloved toad thusly
Heads up, I just drilled and dry fit my Octarock and used the same 35v 470uf and it doesn’t clear the lid. I’m going to have to remove mine and lay it on it’s side.I was surprised to find any of these 470u caps on my stash, with these 35v being the smallest and even that's huge
I've got BBSs and BBMs on hand, so shouldn't be an issue. Thanks for the heads-up, thoughHeads up, I just drilled and dry fit my Octarock and used the same 35v 470uf and it doesn’t clear the lid. I’m going to have to remove mine and lay it on it’s side.
If I recall, my original Frantone Cream Puff had a 1000uf for the power filtering470uF wowza. Half a millifarad![]()
