DGWVI
This one's a twin formant filter type deal, so you can make your guitar spit vowels and maybe some expletives. MadBean's HoneyDripper 2015 board.
Stock it's a great circuit, though it does have its limitations which I've tried to mitigate with a handful of mods. There are some other things I'd like to try, but I want to wait until I can get my hands on a few more PCBs before experimenting any further, so I can compare and contrast.
So, the mods I've done are
Anyway, here's the demo. I'm just waking up, so it's pretty meh. I'll probably get a better one done later today
EDIT- I knew the power supply I was using was shit, but didn't realize it'd added all the weird extra noises
- R1 (100K) replaced with a 1M trimmer have it set for 1M in the vid. This is to increase input impedance, and while subtle I do enjoy it
- R5- has been increased to 270k for more input gain
- R6 has been increased from 4.7k to 270k to give it more zippiness (according to Mark Hammer, though he suggests 220k). Definitely gives it a little something extra
R9- has been replaced with a 250kB pot, I'm calling this balance, as it adjusts the amount of signal going into the lower tuned filter. Highly interactive with the sweep pot, also effects decay timea bit- R18 is 2.2k because that's what I grabbed
- R44 (4.7k) has been added between pin 1 of the Sweep pot and ground to limit the signal dumped to ground and increase the usable range
- Sweep pot has been changed to Anti-log taper from linear. Value remains 10k
- C1 has been increased to 27n to allow more into the circuit
- C2 has been decreased to 1n to raise the cutoff of the clipping circuit
- D3 & D4 have been changed to BAT46 for a bit more sensitivity
- IC1 is LM1458, though TL072 works great here as well
- IC2 & IC3 are currently TL974, though I'm still experimenting with those. The 974 seems a bit dirtier than the 324
- Edit- I copy and pasted from my notes app, and didn't catch it. R9- is stock. R22 has been swapped for a pot to effect the gain of the first peak detector. Guess I'll need to relabel that pot
