Snicksound
A few years back I built a DOD 280 optical compressor clone on perfboard. Love the simplicity of this circuit and it makes my bass sound so much bigger without being too intrusive.
Unlike the original, it's running on a bipolar power supply with an LT1054 charge pump. I wanted more headroom so I could play 5-string bass into it and not worry about it.
Anyway, recently received my protoboard and needed the 1054 so I could so some 12V projects (1054 is rated for 15VDC, so you can do -12/+24 easily). Took the 1054 out of the comp, put a 1044 instead. Now the 1044 was no longer working... Bah, I'll look into it later.
Today I finally opened it back up only to realize... I had installed a TL072 in lieu of the charge pump.
Put a 1044 in... problem fixed, pedal still sounds glorious!
