I build many many many pedals. Unfortunately this pedal is kicking my butt. I built it with the best parts known to man as per usual. However the issue lays within the volume control. It works very well but it’s way to loud! I mean unusable almost if that makes sense?
If I don’t have the drive knob engaged, I can use the volume knob freely with no issues and it acts as any other volume know should. When I spin the drive know to even 9 o’clock the volume seems to just double or triple what it was prior to using the drive.
If I set the drive at noon the volume almost has to be in the off position and 1mm turn and your ears are bleeding…how can I fix this? Change pot value? Am I missing something? Everything in the pedal works great but as I mentioned, I can’t use this live in fear of bumping the volume even a hair!
I really like this pedal! Hoping I can fix this issue! Any help is greatly appreciated!
Below is how the knobs are set and this too is insanely loud. Volume is all the way right and drive is on the left.
Don
Don
