KindCanuck
- Build Rating
- 5.00 star(s)
I wanted something to be a backup to my tube amps, and something I can easily attach to my pedalboard.
Reading through the thread on the TPA3118 power amp board, I realized I could do it!
I found some tiny simple amplifier boards that run off 5v, so I can use the USB port on my Fender Engine room instead of a 9v port. I was doubtful of them, not thinking it would be enough to power my 8ohm v30.
Boy was I wrong! It is perfect, gets plenty loud, but I doubt that it would be good in a band context, but it is definitely loud enough for any solo practice. Exactly what I wanted!
I use a buffer based on the simple jfet buffer schematic, using a 2SK30 into a B1M pot for volume. I have a power switch with a filter cap and polarity protection feeding it all.
At first I had to enlarge the jack hole, as the odd nut was grounding out on the enclosure. I probably won’t use these style jacks again. I’ll get all plastic ones to eliminate that problem
