ClippyTheDiode
I added Bluetooth to my Headphone Amplifier. The upper right toggle turns the module on/off and the blue LED shows BT module status. I wired in a 7805 voltage regulator to power the BT module with 5V. 10k resistors were used between the BT module output and the wipers of the Dual POT. There is a little bit of audible noise (clicks and chirps) during the quiet parts but once audio is playing, (guitar or BT) it just drowns out the noise. The regulator and BT modules are stuck to the main PCB with double sided foam tape, and a tack of e6000 on the corners. Even with the case closed it connects to my phone just fine.
