Mike McLane
 Wooohoo!  Thx!
  Wooohoo!  Thx!BTW, if I'm wanting to run my Part Acc into a power amp do I want to create a bypass toggle for the 220K resistor there, too?
 Wooohoo!  Thx!
  Wooohoo!  Thx!Either that or a trimpot to attenuate it down to more pedal-useful levels. Trimpots are what I do in my "commercial" units.Wooohoo! Thx!
I use 500k trimpots which are all linear taper, but yes hooked up as a potentiometer, not a variable resistor. Use your ears, they'll tell you what to do.A variable resistor, not a voltage divider. . . yes? A250K? Would my ears tell me the best output for a particular (Class D) power amp or do I want to hook it up to a oscilloscope and test for line level (3.5v p-p)?
I think I have got WTYS selective Hearing loss!But my wife already tells me what to do?!?!?!?!?
Nope, but close. Pin 6 of the tube needs to tie directly to HV, not to pins 1 and 7. Pin 7 does tie directly to pin 1 though. Tying pins 6 and 7 together will prevent the whole thing from working.Would appreciate feedback on the wiring of the cathode follower (the area in the RED box). Did I get it right?
View attachment 49373View attachment 49374
 (ha ha). I see what you're saying. . . . Thx!! I assume I can pull that HV (full HV, not post plate resistor) from anywhere on the board?? I've since redesigned the layout so that an "HV buss" runs down one side of the board and a "GRD buss" runs down the other so the current flow of certain segments are flipped relative to conventional amp layouts. Given that the pots will lie directly against the backside of the board with the tubes flanking either side this seemed to make more sense than the conventional layout scheme. Seems to have more economical wiring, shorter runs.
 (ha ha). I see what you're saying. . . . Thx!! I assume I can pull that HV (full HV, not post plate resistor) from anywhere on the board?? I've since redesigned the layout so that an "HV buss" runs down one side of the board and a "GRD buss" runs down the other so the current flow of certain segments are flipped relative to conventional amp layouts. Given that the pots will lie directly against the backside of the board with the tubes flanking either side this seemed to make more sense than the conventional layout scheme. Seems to have more economical wiring, shorter runs.Wife Tells You Something.I think I have got WTYS selective Hearing loss!
Yessir.I assume I can pull that HV (full HV, not post plate resistor) from anywhere on the board??
People who have heard me play would tell you that’s a good ideaTying pins 6 and 7 together will prevent the whole thing from working.
