What's your latest Epiphany?
That's just adding the chord's 5th as the bass note, right? <Tries to remember some of them theory videos on SBL> Mind you, I have never thought to do this in any tuning, so thanks for gifting your epiphany to me.
I could be totally wrong but Say the root is C so the other 2 notes would be a G making it a Cmaj7?
No. A Cmaj7 chord has C, E, G, and B (technically the G is optional since the fifth is implied by the surrounding harmony.
if you’re playing a C power chord with a G in the bass, it’s still a C chord. Just a different inversion though (second inversion, but technically that’s debatable since a power chord is just a dyad with implied harmonic function— could you say it’s a quintal dyad in first inversion? Could you say it’s a quartal dyad in root inversion? Yeah to both of those. That’s just music theory nerd dumbness though.)
I will have to refer to you on this because you are zooming way over my head on theroy, but to be a pain in the ass I will leave this here and say We were trying for a Cmaj7 but got tired.🤣
<Using the forum to have theory thoughts out loud>
I think all this means I might have been correct. Giving it some more thought, the "implied harmonic function" is because it has no third to make it deterministic?
Maybe. I'm just playing along, using it as a thought exercise, because I don't really know theory.
I’m with ya I know enough about theory to know I don’t understand it… I just know the sound a guitar makes when someone lies “ I know theory.”🤣
Pretty much, the gist of it is that unless you have a B somewhere, it’s not a Cmaj7. If you have from low to high:
  • CG: it’s a C power chord, aka “C5”
  • CGC: still a C power chord, aka “C5”
  • GCG or GCGC: still a C power chord, but an inversion of it. We could call this C5/G
  • CEG: C major
  • CGE: still C major. It doesn’t matter what order the upper notes are in
  • CEGB: Cmaj7
  • CGBE: still Cmaj7- it doesn’t matter what order the upper notes are in
  • BGEC: C major in 3rd inversion. We could call it a C/B or Cmaj7/B
  • EGBC: Cmaj7 in first inversion (aka Cmaj7/E), or Emb6. Which you call it depends half on preference and half on the function within the harmony. Minor flat-sixth chords aren’t all that common outside of chromatic line cliches so most times the better choice would be to call it Cmaj7/E
  • CEB: Cmaj7— the fifth isn’t all that important
  • CGB: debatable, but for all intents and purposes it’s still a Cmaj7 since the presence of a major 7th interval implies a major third— since the fifth is included, we know it can’t be a C+7 or C°maj7 chord (neither of which is common *at all* anyway) which leaves us with Cmaj7 or C-maj7, with the contexts of minor-major-seventh chords and major-seventh chords having virtually no overlap, so it’ll be very clear what the intent is.
If there’s just C and G, it’s absolutely just a C5 “power” chord.
Probably over complicated things quite a bit there, but hopefully I didn’t make things too confusing with my incessant rambling 😅
If you ever need help with what to call a particular unusual chord or inversion, I’m here to help though— I promise not to get into debates with myself over technical minutiae that doesn’t have a name because it’s not quite significant enough for music theorists to care about 😂
  • CEG: C major
  • CEGB: Cmaj7
My fav Cmaj7. If you guys wanna play with chords and theory, check out https://www.oolimo.com/en/guitar-chords/analyze
Talk about epiphanys!!!! oolimo is a really weird name for every chord you never knew the name of!!!! It even does chord names in alternate tunings......(excuse the technical problems with the picture, I think I have it now)
  • CEG: C major
  • CEGB: Cmaj7
Wow that’s a lot man, not going to lie That’s a lot to try and absorb, but I did just learn something… I think….. I know who to hit up now for theory questions for sure.
I just mean that power chords in 99% of songs will still fit within the diatonic confines of the key center, and in 99% of those cases, the power chords will unambiguously imply the chord quality just by its role in the harmony. In song that’s in C major, a D power chord will almost always imply a Dm, because that’s the quality of chord that naturally resides as the ii of a major key. If the song is in C and I play the power chords D5, G5, C5, it’ll almost always be functioning as a typical ii-V-I turnaround, so Dm G C is implied— there is no D major chord naturally occurring in C major, nor is there Gm or Cm unless they’re examples of modal interchange (or are non-diatonic chords setting up a secondary dominant down the line), in which case the melody will likely clarify those outliers anyway.
If I play E5, C#5, A5, B5, it’s pretty clear that I’m doing a I-vi-IV-V in E major, so we can pretty confidently say that the E, A, and B chords are implicitly major, and that the C# is minor.
All I know is a major chord is one containing the 1, 3, and 5. A minor has a flat third.
Beyond that, if it sounds good, it is good.
