kylewetton
Sheesh, okay so here goes. I wanted to build a green russian but opted for an alternative layout because I don't have the right cut of veroboard for the bigger one.
Here's the schematic, following this diagram is two questions I need help with
So i have two questions
1. Can someone please clarify which direction I should read the pots?
What gives me pause here is that either volume 3 is going to ground or sustain 3 is going to ground, I have a limited understanding that pots should have terminal 1 going to ground, so if anyone can help here that'd be great? Do I read these as 3-2-1 or 1-2-3?
2. I'd love to shoehorn this tone switch into this build, but I'm unsure how
Specifically where would SW1 be in the schematic above? and, would the other end of the switch still take Tone 3?
Thank you very much
Kyle
Thank you very much
Kyle
