So, if I'm understanding this correctly, one can press the footswitch a "normal" duration to toggle the first relay (e.g. a bypass), and then press and hold the switch to toggle the second relay (e.g. a channel switch), but then go right back to a short press to toggle the first relay?...
A smart relay breakout board. Two relays and a single footswitch. Holding the footswitch turns on the (optional) second relay which you can use as a DPDT for whatever your heart desires.
You can set it up as you want, short press for both channels, or short for pedal and long for hold, or any mix you want. But what you described is my default coding.So, if I'm understanding this correctly, one can press the footswitch a "normal" duration to toggle the first relay (e.g. a bypass), and then press and hold the switch to toggle the second relay (e.g. a channel switch), but then go right back to a short press to toggle the first relay?
Sure thing, just need some down time to work on the code. Interested if there are particular use-cases you're looking at.![]()
I might be in for a couple of these when they're available!
My initial thoughts are the following modes:
- Two independent channels with a footswitch each. Hold to temporarily change state whilst you keep the switch down.
- Two channels with one footswitch. Hold to turn on/off second channel. (Good for boost or voicing).
- Two channels with one footswitch. Hold to change channel.
- Two channels with one footswitch. Double tap to turn on/off second channel. Hold to temporarily change state.
I am by no means tenured, but I have found the following useful:Does anyone have tips for laying out IC heavy designs? I feel so much more challenged by them than transistor based ones.
Happy to pay it forward. Only got into DipTrace because you shared your handy little pot template. Still use that on every build and can’t find a realistic improvement!thank you so much @szukalski !! will hopefully have a nice layout to show off because of all of your advice![]()
I like the diode footprintIf you think of anything please lemme know - the only thing I've changed on mine is making it bigger so that the corner standoffs are less likely to bump into pots.
Also here's a rough attempt of the schem I posted! Not super satisfying of a layout but might reach the threshold of tolerable enough to get fabbed
Nice layout, only things I could mention:
- The 1u film cap footprint is only 2.5mm, maybe want 4.5mm unless you have tiny 1u caps.
- You could look at moving the charge pump into it's own corner. I didn't mention it earlier, but I "try" to keep all the power supply stuff isolated from the rest of the circuit where possible. That goes double for charge pumps.
I love how the footswitch fits. Would you be willing to share the DipTrace component/footprint? I prefer the "other" way, but that's just damn hot.Got boards in yesterday and did some dry fits and pattern edits for the next batch:
By the way, if the price of the relay is painful (I see them around €2.50-€3 each and end of life), then the FTR-B3CA4.5Z is $0.71 from LCSC. Different footprint though.. but profit margins..
