Fama
Hello!
I built the Informant Overdrive a while back, but I'm not in love with it. At least with my Strat that I normally use, which is obviously pretty bright sounding, it's not a great match. If I turn down the tone control on the guitar I can get a really nice, smooth, distortion with a lot of clarity on tap with the Cut control. But with the tone control down, it sounds more gritty and a bit grating, even with the Cut control at full.
The thing is, I don't want to always roll down my tone control to use that one pedal. So I'd like to implement a similar (?) low pass filter in the pedal itself - not sure if being before the clipping stage is important or not, but it might be, so preferably before that.
Here's the schematic https://docs.pedalpcb.com/project/PedalPCB-Informant.pdf
My thinking was that I would snip the leg from R6 that goes to R7, and add a 5k trimmer and a (for example) 10nF cap going to ground. That should give me a 1k 10nF to 6k 10nF RC filter, which should give me 16kHz with the trimmer at zero and 2.65kHz with the trimmer at full - plenty of range to work with I think.
The issue is that I'm not sure if C4 or R7 interfere with this at all? I'm not that good at electronics so I have no idea about that.
(I also had some comments last time about "Just build a RAT", but I've got this done already, I like it otherwise, and I love how it looks, so I'd like to use this one if possible)
