I don’t think you misunderstood. Unless I misunderstand.I was under the impression that the issue isn't just the loud output volume, it's that the actual tone of the effect doesn't sound good unless it's loud. Reducing the overall volume output so the knob can be turned higher would solve that. Using a different taper would not because it would just change the position of the wiper on the pot so you'd still have to turn it up to sound good. I probably misunderstood.
How I understood as well.I was under the impression that the issue isn't just the loud output volume, it's that the actual tone of the effect doesn't sound good unless it's loud. Reducing the overall volume output so the knob can be turned higher would solve that. Using a different taper would not because it would just change the position of the wiper on the pot so you'd still have to turn it up to sound good. I probably misunderstood.
