Fama
Hello! I've built the Aion Anubis (https://aionfx.com/app/files/docs/anubis_documentation.pdf) a while back and it's very noisy when I use it in the FX loop of a Quad Cortex.
The Body control also affects this hiss tremendously. There's a specific sweet spot around 3'o'clock where the hiss is reduced dramatically.
I also noticed that if I use the Lightspeed clone I built (Southern Lights from Fuzzdog, Lightspeed specs) the hiss is decreased substantially while the sound is similar - with more gain, if anything.
Here's the sample using a looper feature, I tried to add comments to Soundcloud but apparently I got blocked by their spam filter after three comments.
I'll list the riff repeats:
1st: All pedals off
2nd: Just the Lightspeed
3rd: Anubis with Body set to sweet spot
then I turn the Body control down, you can hear a massive increase in hissing
4th: Anubis with Body turned low
5th: Lightspeed + Anubis with Body turned low - the hiss disappears almost completely even though it sounds almost identical otherwise, maybe a bit more gain.
I've tried with some buffers before the Anubis but I don't think it has helped much. I use a 1Spot Pro CS 12, most pedals are daisy chained, I give the Anubis it's own isolated power but that doesn't make any difference.
How could I get rid of the hiss? Is it an impedance thing? Or would a small buffer pedal help?
One obvious answer is "put it in front", but I would like to be able to use effects on the QC before the Anubis, like pitch shift, octaver and so on.
Edit: Actually the Aztek Sunn (https://www.dropbox.com/s/2avxcdetkyk59ez/Aztek Sunn Doc.pdf?dl=0) from Moonn is acting in a similar way.
According to the manual, the QC send outputs (which I'm using) have an impedance of 560 ohms.
1st: All pedals off
