MBFX
The Electra circuit is really easy to build, makes a lot of gain, seems to not care about which transistor you use, and is also a good boost with a lot of color if you skip the clipping diodes, so it's perfect for a beginner like me.
I had an idea of making an Electra with a selectable clipping section, but the volume cut when the diodes were engaged made me sad. I decided to make another Electra boost circuit that fed into them, with a different resistor ratio in the voltage divider section to make the gain match.
I thought it worked, but I had actually done something a little different. I made a booster into a booster, and the diodes weren't doing anything. Going to report back
