VanWhy
I'm not sure what's going on with this one. I built a PPCB Sandspur and a Uberfuzz and want to hook them up to the JMK Paralyzer which takes both circuits and mixes them in parallel with the ability to blend.
The problem is when I blend to one side I can get signal but when I blend to the other side I get no signal. When I probe the inputs of the circuits, I get signal for both just fine so they are both working.
One thing to note is that I did pull one of the pot pads on the bottom of the Paralyzer board. Anyone familiar with these boards know for certain that that could be the culprit? The top pad is still intact. If I need to solder to the trace I guess I can try that next.
I'm not using a phase inverter but I would think that you would just get something that sounds bad, not no signal. Not sure if these need a phase inverter.
It's a wiring mess now but I am including the pics.
