The build docs call for a SPDT Mini Slide for the internal clipping switch. Can I substitute that for a short shaft On-On SPDT, assuming there is enough clearance to close the enclosure? Or, alternatively, could i install a long shaft On-On switch on the underside of the board and use it as an external switch? I have everything i need except for the slide switch and am trying to avoid making another components order.
