Dear fellow enthusiasts,
I built an Ocelot on a breadboard. I like to build on a breadboard first before soldering. What a fantastic pedal! Everything works as it should be. DIRECT, OC1 and OC2 all work. I'm going to use it for bass so I removed the OC2 potentiometer by replacing it with a 100K resistor between 3 and 1. I also removed the DIRECT potentiometer by connecting 1 and 2 and adding a 100K resistor between 3 and 1. It will be a single-knob pedal.
(1) See audio clip. I hear a disturbing noise in the background. It's a kind of crackling sound. This sound is only heard when the strings vibrate. By muting all strings the sound disappears. By turning off both pickups on the bass, the sound disappears. The tone knob on the bass has no influence. I used a Faraday cage to rule out that it came from outside, that is not the case. I also replaced all the ICs. No effect. Anyone?
(2) Because I don't use DIRECT and OC2. Are there options to make the circuit smaller? If so, can someone indicate what the circuit will look like or which circuit parts or components I can leave out?
Thanks for your thoughts!
Jac.
Jac.
