Cybercow
DPDT On-On-On Toggle Switching Techniques for 3-Way Switching:
One of the more common modifications to most any pedal circuit is to inject a means of toggling a capacitor value into the signal path, varying the depth of a chorus, and or some other audio manipulating section of a circuit. Basically, it’s adding a ‘micro-miniature capacitance decade box’ to a circuit.
One of things always that bothered me about many of the 3-option mods, is that the order of the cap values were not linear. In other words, instead of getting “Low, Mid, High” toggling action from a 3-way toggle, one would get a non-linear “High, Low, Mid” or “Mid, Low, High” switching order as the 3-way toggle was activated across its switch pattern. So I set about to see if that could be changed to provide a Low to High transition.
Most such three-way toggles I’ve seen used in such mods are simple SPDT On-Off-On toggle switches. And while those do work as ‘micro-miniature capacitance decade boxes’, they do not allow a Low to High switching action. So I took a DPDT On-On-On switch and started futzing with jumpers and layouts to see if a Low to High switching action could be achieved.
The first one I came up with was for a chorus depth mod which called for a 330pf, 100pF & 47pF set of caps. By applying criss-crossing jumpers across the 4 outer lugs of a DPDT On-On-On toggle switch, adding one leg of each of the 3 different caps in order of value directly onto three of the toggle’s lugs and tying all three of the dangling cap’s legs together, a nice ordered switching appliqué is provided. Just attach the 3 tied cap legs as one leg of the original cap in the circuit and the unused center lug of the DPDT On-On-On toggle to the other leg of the original cap and you get an ordered 3-way swathing toggle that will operate from Low to High. Just mid the orientation of the switch when it’s mounted so it matches the labeling on the enclosure. (see images below)
Another configuration using a DPDT On-On-On toggle for an ordered 3-way toggle is to jumper across one pair of corner-opposite lugs together and the two center lugs together. In this configuration, only two caps are needed and if one uses box-film caps, they can be super-glued directly to the body of the toggle switch. The caps are soldered directly onto the toggle in a manner shown in the images below. (To describe it with words just seems too wordy. And a picture is usually worth a 1,000 words. Image below next paragraph.) And also provides an ordered Low to High switching action.
With only two cap values used, advantage of the jumpered DPDT On-OnOn toggle allows the caps to be used in parallel in the “Low” position. The example images below are being used as the input cap value option for a boost circuit, (LPB, RM, etc), and the Values may vary depending on your tastes/requirements. Here, I’ve used a 6.8nF and a 3.3nF to yield a low of 10.1nF, Mid of 6.8nF and a High of 3.3nF - which work nicely in this circuit.
4-Way Rotary Switching Techniques for 4-Way Switching:
This is just a simple dead-bug faction method of obtaining an ordered switching method of different valued components.
6-Way Rotary Switching Techniques for 6-Way Switching:
For instances where up 6 options are desired/required, SmallBear provides a nice solution with a 6-way (SP6T) rotary switch and a link to a nice little PCB from OSHPark for mounting the SmallBear switch and your components for when & where such switching is called for. The PCB, switch and components will fit neatly into the depth of a 1590B enclosure
That's this months' modification article from me. Happy building!
