Locrian99
- Build Rating
- 5.00 star(s)
It feels like it’s been awhile since I’ve built anything been meaning to put this together for awhile but have had a hard time finding a parts list I trusted. Got a hold of a copy of the old adhd 2.0 schematic and figured out what’s what.
In case anyone is looking for it this is for the 2.0 for the germanium just add the diodes.
C9 is not in the old 2.0 schematic but it’s in the power section right before the op amp so I left it in.
Build was pretty simple. I went ahead and used the buffer bypass board. Not sure why I used some of my few thru hole 5457 for a buffer instead of smd. Laziness I suppose
. I socketed the diodes which I typically don’t do but with this build I thought it made sense since they can be removed for a different version.
Buffer board worked awesome with some headers made for a very clean look.
This was my first build using my newly acquired rocket sockets. Highly recommend them. Also first time using this domed led bezel from tayda love the look. Though I wish I would’ve used a slightly larger clr 8.2k still isn’t big enough for the blue.
Sound wise… it sounds like an ocd to me. First time playing a 2.0 or germ variety but it’s been awhile since I’ve had an ocd around (gave last one
to a friend). From my memory this sounded fuller to me than the 1.4 did. Maybe a more bass and obviously with the germs a bit more compressed. I tried some 34a’s I had from SBP and some of the red band itt from small bear. I ended up with the red bands. They were a bit lower vf (.27) and I preferred that.
Enclosure is a cream powder coat from tayda.
